at 8am this morning a red 35 GTR in the open air carpark at the airport ..
he gave me a run from the lights at Fyshwick heading to Queanbeyan :) it not to bad looking :)
there is a white one parked on the main road in deakin all the time :( makes me sad its not in a garage - or a carpark....
https://www.sau.com.au/forums/topic/30059-spotted/page/900/#findComment-7133000
No you just tried to give him a run. Stop telling us how you are driving like a dickhead.
  • Like 3
https://www.sau.com.au/forums/topic/30059-spotted/page/900/#findComment-7133691
May have been me. What car were you in? I waved at a white R33 GTsT I think it was.
yeah that was me.. white GTsT with custom black "euro" kinda look paint on the front bar.... DRL's and gold mags.
had to do something when i repaired the cracks..
you came down past the CCC building with me until i turned in there..
https://www.sau.com.au/forums/topic/30059-spotted/page/900/#findComment-7133728
Yep that was me.
https://www.sau.com.au/forums/topic/30059-spotted/page/900/#findComment-7133731
umm, by that I did not mean I raced him... I mean we drove quickly to 80kph... defiantly not a race....
https://www.sau.com.au/forums/topic/30059-spotted/page/900/#findComment-7133966
Known as a "race" to the speed limit. That behaviour is not condoned as us "skyline" drivers attract enough attention and don't need to give police any more reason for "random inspections" or piss off the general public as they are easily identifiable car.
Try to think about who is around you when you drive in such a manner and don't post it on here. It is a public forum after all.
https://www.sau.com.au/forums/topic/30059-spotted/page/900/#findComment-7134117
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
    • And, given that you're in NC, go buy an LS7 or something equally sweet and piss that crappy old RB off. Or call up Wesley Kagan and get his help putting a Merc V12 into it.
    • Do a compression test, and a bore scope on the cylinder that lost parts of the plug. Chances are, that cylinder isn't so happy anymore...
