Spotted 2 silver r33 gtst's
First was near the servos at gungahlin around 5.15pm. Had a Trojan sticker and blue calipers.
Second was along Lake George and down towards bungendore, plates were NSW mr33yo. Had an SAU sticker
Edited by gtr judd
https://www.sau.com.au/forums/topic/30059-spotted/page/903/#findComment-7137542
haha there is a postman going around Yarralumla, who owns a r34, I always see him when im warming up the car, working on it, cleaning it, or driving.. everytime he sees me he pops the front wheel up :D best f**king postman ever!
he even noticed my car through the gate out the back when it was written off, then he gave me places to get parts for it ;)
so I saw him today when I was parked on some fire trail (answering the phone) when I was leaving he gunned it holding the frount wheel up through gears...
haha made my day!!
thanks mr postman !
https://www.sau.com.au/forums/topic/30059-spotted/page/903/#findComment-7138115
Hey Guys,
Haven't really been on the forums much over the last year but yeah, I'm definitly around :D
I remember that lol, sorry about the weird look, it was more like a sympathetic look in my opinion... i know that scrape feeling -_-
And that yellow. 34 in calwell I see every Friday
I like to accrue my spotting, so as follows;
-saw that yellow r34 with the datsun badge at calwell shops when i was rocking up. just fitted the RF FMIC and usually my bumper clears the kerb but the bottom if the hose clamp just scraped and he gave me a weird look.
https://www.sau.com.au/forums/topic/30059-spotted/page/903/#findComment-7138211
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
