butt failed
Shaun not Shuan - Doh !
+ you forgot Shorn and Shawn
Huge butt fail - like ghetto butt fail :(
Shawn was the first one - you butt failed ! Never seen Shorn :O I guess I forgot Shawjn (silent J) :D
Edited by RosieR34
https://www.sau.com.au/forums/topic/30059-spotted/page/909/#findComment-7148471
Spotted Silver 33 GTS-t with a minor overheating issue on Athlon last night around 9pm
Stopped to lend a hand but left just offering advice :thumbsup:
Flush properly
Make certain thermostat is in correct way (replaced that day)
Use Coolant
Do with heater on full
- is water pump pumping ?
Bleed air off before driving, if possible
Check water level after driving for a while
Oh - it was a relatively new Rad as well.
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/909/#findComment-7149234
Black R35 GTR in the city about 2pm parked outside bags to go on Bunda street (ACT plates)
AND
Silver lamboghini gallardo, also on Bunda street about 1:30pm - had the top down and looked like you could fry an egg on the drivers bald head!
the only way you can afford a lambo at a young age is if you win the lotto....
its always the old bald guys driving expensive cars...
when im retired ill be owning some insane supercar just for fun, then ill get a heap of plastic surgery so I don't look stupid driving it......
https://www.sau.com.au/forums/topic/30059-spotted/page/909/#findComment-7149421
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
