Just had a mini cruise with 5hiv.
Mate your car looks loverly. :thumbsup:
Spotted that Blue R33 with GTR style wing at Charnie shops just now too. Chick got in a growled away. Guessing her name is "Madi".
Also a Silver S1 R33 out the back of John Mcgrath's in Belco around 3:20pm. Had a "Be Patient, I'm Lowered" sticker on the rear bumper.
https://www.sau.com.au/forums/topic/30059-spotted/page/915/#findComment-7161586
that 33 was near my place a couple of days ago, that sticker is huge :/ I don't see a point to it because from what I saw it wasn't lowered haha
saw a white 33 in southlands just before, big chromies went to park behind it, tho mum didn't want to walk too woollies haha
Edited by ..::R33GTS-T::..
https://www.sau.com.au/forums/topic/30059-spotted/page/915/#findComment-7161644
Thanks mate im still not done with the car more to come :)
Saw a white R32 going to trojan as i was leaving
Black R33 S2 gtst on stock wheels in UC car park
https://www.sau.com.au/forums/topic/30059-spotted/page/915/#findComment-7161778
Yesterday i spotted a guy dropping his bike at the lights. On the left with the bars turned left, i wonder if he has a clutch lever. >_<
Also some fools rc aircraft over the new ASIO building at Russel. :O It looked like it had wingtip diehedrals and a dark cockpit (camera?), so probably a fpv foamie of somekind.
Thats just asking for trouble.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/915/#findComment-7163266
Wonder how long till that person will be safe before they find him
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/915/#findComment-7163529
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
