Spotted!!
Shell
Spotted Richard (I think!) on Drakeford at about 1pm.
White R33 with black rims near Chisholm shops about 1pm and then saw him again I'm pretty sure, same area, about 6.30pm.
yep would have been me after dropping the GF off.
Got a toot from some one in Queanboganville yesterday. Didn't really see who but it looked to be a dark grey ford ??
Stuck my arm out the window for a backward wave.
yep, I got a toot last time I was there.. and im going back to pick up the sister in about 20mins....
saw a grey 32 young guy driving, heading to tuggers from Calwell way yesterday
and what seemed to be a s13 siliva with a skyline bar... had a p plate zip tied on the back, then it went and was fluttering like to tomorrow in tuggers last night at about 7pm?
that is by far the best looking 34 I have seen, its perfection !
tho is it just me or does the numberplate look a little wonky :P
Thanks for the compliment Andrew, very much appreciate it, and I do love my 34 ... but have you seen Richards 34, I've only seen it in pics but it is a lot closer to perfection than mine.
Oh and the number plate is straight but yes I agree it does look a little wonky in that pic .. sh*t .. might go check it just in case!! :wacko:
7pm...Silver S2 R33 with R34 GT rims, P plate, young dude driving and 3 young passengers in the back. (none up front) WHY??? :wacko:
My guess ...... 'no Maccas in the front dude, get in the fnckin' back with that sh!t where I cant see it' .... :P
Oh well .. just adding to the conversation .. :glare:
if Richards AKA: Rosie, I have seen it once , it does look really nice :)_
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
    • Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
