Nope. It was clearly setup for track use and tbh all the specs that I saw on it would've enhanced the track experience. Also the fact it has a Nulon sticker my guess is that it went to the Nulon Airport runs or maybe even WTAC. I'm not a fan of the big wings and such but when used for the track then much respect for the build is given.
https://www.sau.com.au/forums/topic/30059-spotted/page/960/#findComment-7417769
Was this the one you've seen? i see it fairly often around belconnen
If so its actually set up as a time attack car, stripped interior , responsive 330kw, fully adjustable suspension and arms i believe 10697184_1560421994169279_90347070782887
Edited by JimmyS
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/960/#findComment-7419294
Yeah looks like it! It was very impressive to see. I live near belco so good chance that it's this one. Looked very intimidating on the road, loved it.
@Bill haha nah, she was at work! Or else I would've picked her up and hunted for this GTR to show her :P I tried looking for it down my street but no dice. Wanted to take a pic.
Thanks for clearing that up Jimmy.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/960/#findComment-7419357
Yeah bugga!! Mums are never around when you need them ;)
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/960/#findComment-7419795
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
    • Not great at getting the camera out fast enough for cars driving. Even in traffic. S15 is in front of the kei truck.
