Hey i think i might have noticed you but wasnt really concentrating. I used to see the candy van most days but didnt think you noticed me
heh fair enough! Caddy's goooooone now, so it's just the white R (and the CBR once I've got a few things out of the way :D)
https://www.sau.com.au/forums/topic/30059-spotted/page/963/#findComment-7431338
In Mitchell this morning, and saw a maroon r33 from Vic with the oddest sound.... rb? sounded like a 4 cyl.
Maybe its like that guy who came to the bus stop when we were meeting for a cruise. He had some 4 cyl on 20psi instead of an RB. Its a bit strange in such a heavy car.
https://www.sau.com.au/forums/topic/30059-spotted/page/963/#findComment-7431909
Yeah i know the Caddy is gone. Im trying to sell the Stagea to fun other stuff including buying another road bike.
https://www.sau.com.au/forums/topic/30059-spotted/page/963/#findComment-7431959
Pretty sure that was a R33 GTR wasn't it?
https://www.sau.com.au/forums/topic/30059-spotted/page/963/#findComment-7431960
Yesterday morning in Belco, Green 32 parked on Laithlain St. I'm pretty sure it was DIY Mik.
:yes: Most awesome egg and bacon rolls at Chris's takeaway. Actually everything there is very good. And im very fussy.
ooooo yes the ZX10R....what a spastic bike lol. I honestly have no idea what practical use that monster has on public roads :P
Intimidation. There not even that great at the track because its too much...... unless your a total nutcase speedfreak.
Oh, and 200kph wheelies.
Edited by D.I.Y. Mik
https://www.sau.com.au/forums/topic/30059-spotted/page/963/#findComment-7432605
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
