Whaaaaaaaaaaa
That's bloody weird Sin...lol. There's too many white ones getting around now! Gotta do something to make mine unique lol...but goddamn, the aftermarket exterior aesthetic parts available are very limited or ridiculously expensive :( wouldn't mind a front+rear lip/splitter, maybe find somewhere I can slap some vinyl...haha
https://www.sau.com.au/forums/topic/30059-spotted/page/983/#findComment-7523345
Spotted and parked the Wagz next to my Ex 33 4Door at Charnie shops this evening!!!
First time I've seen her since... :(
Needs a WASH! :/
I hope it sinks in so you buy another one !!!!! :( Pleeease?
spotted a black R34 GTT pulling into Charnie
Edited by RosieR34
https://www.sau.com.au/forums/topic/30059-spotted/page/983/#findComment-7525255
Spotted this absolute beauty today
A big part of motoring history restored to its former glory
Murray Carter raced in the ATCC 15 years straight and has been racing since 1959.
Still races at 90 !
This is his car he raced 1986, 87 and 88.
Beautifully restored by Graham Taylor
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/983/#findComment-7525482
    • I would not replace the gauges. A well setup tune should never require any of that. I'm of the opinion that if you can't safely hand over a car to your parents to drive it's not fit for purpose and more engineering work should be done. Honestly I'm not a fan of external boost controller boxes either but if you have to you can shove the controller into the glovebox or something once it's set up. Tee it off the OEM MAP sensor. Also you probably want to put a two pin plug on the new solenoid, bolting it to the OEM location works. Just separate the wastegate line and compressor outlet so it will work on a 3 port solenoid, kevboost was walked through how to do this on an RB26, same idea just different locations on an RB25. You may have to remove the restrictor in the OEM hoses if they're still in there.
    • Yep, it's why in Australia we never brought in the 1 child policy like China.  China can't afford to use the shit they make in their own country as it's too much to risk having only one child...  Or maybe that's how they test their shit before they send it to Australia - they use the second kid that families had when they weren't supposed to as the tester?  They weren't supposed to exist in the first place so no loss if they succumb to a work place incident?  🤣
    • It's also the reason neither Duncan or I can own a car rotisserie
    • this is the reason we have more than one child right?
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
