Spotted Robs old 4 door 33 looking great out the front of my work. Still rocking the SAU sticker.
HE Washed IT??? Thank f**k. :D
Not a pulsar in Mitchell?
Yes! You were at Repco at 3:30pm. ;)
Also, Black R33 this morn near Mitchell at 6:50am ish.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/984/#findComment-7528176
Yea she got a bath... i felt bads.
Changed jobs no longer parking next to a construction site any more so she'll be a bit cleaner i recon.
https://www.sau.com.au/forums/topic/30059-spotted/page/984/#findComment-7530711
Yesterday at the all Japan day spotted the black35 gtr and owner. I thought it was Kat at first. Talk about doppelgangers. You sure you don't own a 35 as your daily Kat?
I look nothing like Nicole, not sure what you were smoking on the day.
https://www.sau.com.au/forums/topic/30059-spotted/page/984/#findComment-7531218
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
    • Throws on the FS5R30A in most Nissans of this era are actually quite short and direct compared to any remotely modern BMW with the S6-53 transmission. Those things have throws a mile long with rubbery vague everything. Synchro issues combined with a short shifter is just going to break everything even faster.
    • Only thing I'd add...is on recommendation from a good diff shop, I've used mineral oil in my diff including the race car for years. The synthetics can be too slippery and glaze the gears
