Must be a new R35 GTR in town. I keep spotting it driving around town - Spotted this morning at 8:45am going along William hovel, older fellow driving - maybe early to mid 50's? I pulled up next to him but pulled onto Tuggers Park way. :x
https://www.sau.com.au/forums/topic/30059-spotted/page/996/#findComment-7689895
Black one?
If so I've seen it a few times too.
https://www.sau.com.au/forums/topic/30059-spotted/page/996/#findComment-7690166
Spotted an amazingly clean bayside blue R34 GTR with NSW rego on Barton highway turning off onto the GDE, pulled up behind him at the lights and my jaw dropped. Eventually pulled up next to him further up and gave him a thumbs up. Cruised further down the GDE until he turned off into City off Caswell Drive. Also spotted another grey R33 driving near us on until she turned off onto Hindmarsh drive further down the parkway.
Edited by AeroZR
https://www.sau.com.au/forums/topic/30059-spotted/page/996/#findComment-7691125
  • 5 weeks later...
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
