Spotted!!
Shell
6 hours ago, AeroZR said:
Did spot a white R32 GTR on Majura Parkway in the last few weeks, and a silver R35 in Nicholls. Other than that, only seeing R33 GTST's around.
Ooooh mebbe me!! :D
10 hours ago, Anfanee said:
Waiting for it to stop bloody raining.
Also lurking.
Hahaha Fri/Sat were perfect!!
13 hours ago, GTRKat said:
Ooooh mebbe me!! :D
I did take mine out last week/on the weekend. I expect it will make it's way out a bit more soon.
27 minutes ago, RosieR34 said:
I fall under this category. I should get it back tomorrow. Been 7 months :(
So you have another 2-3+ months to go...
3 hours ago, Sinista32 said:
You will likely hear the rumble of my GTR over the weekend. I have a GTR clock with your name on it too.
Excellent. I havnt forgotten about it i swear. Will pm you
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
