Spotted!!
Shell
11 hours ago, MANG said:
Who was in the silver 32 on Johnson Drive near Chisholm this arvo?
I was in the white Stagea.
Speaking of saw a white stagea at the main piallago traffic lights near the airport the other day at lunch time. Maybe Monday? around 1.00 ishhhh
Was in the SugerCube
Spotto, all in Gungahlin over the course of the day....
Red R35 about 10:30
Blue R33 (see this car a fair bit) at around 1 and a black R34 was parked at that time then drove off.
Was window gazing while in meetings... :D
Saw an ACT rego'd 34 GTT, white, having a very spirited squirt on the road out to Tidbinbilla yesterday morning. Anyone on here? A word of warning: as a Skyline owner that's also a cyclist, I'm not going to have a go for being buzzed at Mach 1, but other non-enthusiasts will quickly dob you in with the new 'a metre matters' laws. Careful out there...
  • Like 1
Had a chat this evening with the owner of nice white R33 GTSt at the Lanyon servo. Car looked good mate, plenty of potential there. If a crazy looking bloke in a white R33 4 door gives you a wave, that'd be me (most likely anyway...)
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
