On 03/03/2017 at 4:42 PM, RosieR34 said:
Can confirm as of 12 months ago it use to sit in the Uni Wilson carpark on Marcus Clarke street. Use to see it every day haha
Yea, and may be coming back soon...
I've been sent out to Fairbairn for the moment, so have been driving the other half's car for a bit... but have been giving the skyline some legs lately.
spotted all the skylines recently. ALL OF THEM.
33 this morning with number plates 33 lol
Robs old 4 door a few times at my work....
a Grey 33 on horsepark drive pretty much every night...
a white 33 on horsepark drive...
Also spotted mine back on the road sneakily :ninja:
  • 1 month later...
Spotto...a black R35...in Bungendore(!)
I have seen this car a few times in the area; assuming it's a local.
For the moment, I'm assuming it's the most powerful GTR in town, although that will change...
There's also a scruffy R33 in midnight purple hanging around. Looks relatively stock, just...unloved.
  • 1 month later...
i actually spotted a few last week, saw a 33 in fyshwick at the traffic lights near CMC. had white? front bar i think. Back end was black.
The GTR will be out an about over the next few months, floating between the gungahlin area and the airport.
  • 2 months later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
