Spotted red R31 sedan down in Gordon, R31club stickers on the 1/4 windows, looked real clean. Nice.
Also...SPOTTED LEIGHS CAR! YAAAAAAAAAY! COngrats buddy! Great to see you finally got it. Like the GTSV-i sticker...looks neat :) Man it's a clean looking car.
https://www.sau.com.au/forums/topic/30059-spotted/page/41/#findComment-944112
Also...SPOTTED LEIGHS CAR! YAAAAAAAAAY! COngrats buddy! Great to see you finally got it. Like the GTSV-i sticker...looks neat  Man it's a clean looking car.
woot yea i i was trying to work out what the hell it meant then i put it together
GTS (makes sence)
then take the S and you have SVI (the place i imported it from) thats my assumption of it anyways but i think i will be removing it as well as the gts25t sticker in a while. i am contemplating actually getting some proper letters that just say GTS-T or GTS25T like what you see on most of the other cars around it just looks so average the GTS25T sticker thats on their. but thanks for the comments :D now i just need to put the bigger exhaust on and get rid of the pea shooter :mad:
https://www.sau.com.au/forums/topic/30059-spotted/page/41/#findComment-945471
Man, it's so stock!
Not a bad thing by no means, it's a great base. And i think it's better than getting some Japanese guys half finished mods.
Looks real good man, as soon as i can drive my car again, i'll snag a park next to you :D
08Elf-> Yeah there is :mad: Are you in the Transact building as well?
https://www.sau.com.au/forums/topic/30059-spotted/page/41/#findComment-945550
08Elf-> Yeah there is :D Are you in the Transact building as well?
Yep i work there.
I got the Black R32 GTS-T, stocker.............except the pod filter and exhaust it came with when I imported it from japan oh and the GTR rear strut bar.
What sort of R34 is it? i know it turbo, cos I hear it ppppppssssshin!! down the street at lunch.
Anyone know somewhere there are plans or diagrams for a cold air box, for an R32??
https://www.sau.com.au/forums/topic/30059-spotted/page/41/#findComment-945727
It's an R34 GTT, has an exhaust, Frount Mount, Powder coated white standard wheels lowered and a cold ait feed by the looks of things.
Welcome to the Forums by the way.
Where in the building do you work? ACTEW? TransACT, Teletech? ACCC?
https://www.sau.com.au/forums/topic/30059-spotted/page/41/#findComment-945749
Yeah i reckon. I've been here 3 months now, and i like it, everyone is friendly, etc. But yeah, you're right about not knowing some people.
Either that or some people just don't want to be known. SIt in the back corner alone and don't say a word.
https://www.sau.com.au/forums/topic/30059-spotted/page/41/#findComment-945832
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
