Spotted a blue R33 series 1 as i was leaving my street, waved but he didn't wave back. Then a black R33 Series1.5 on the way to work near Bunnings, waved and got one back. Also spotted a Silver R33 GTR heading to Tuggers from Chisholm, waved and think i got one back. And finally a black Series II with GTR wing near BP Chisholm, waved but got nothing back.
https://www.sau.com.au/forums/topic/30059-spotted/page/114/#findComment-1161813
Ok havent been on for a few days, so sorry guys this is delayed spotted sexy gtst at bout 6 driving towards jerra on the 13th.
Also on da 13th:
*A black 33gts-t black plate ewing rims? at UPS in fyshwick
*A gold/yellow (bit of both very nice like white gold) 33 at 11 driving past bunnings, went past too quick but gotta say it got my attention!
*Another gold 33 on barrier st about 11 15, very tidy chrome rims
*Gun metal 32 near maccas traffic lights (fysh) 1:50pm :)
*White 32 gts-t white 5 spoke rims, vic plates
One of the best days for spotting, and no comments about why i was in fychwick i work as a courier!
https://www.sau.com.au/forums/topic/30059-spotted/page/114/#findComment-1163754
Yellow R34 at curtin shops with the number plate NISSAN yesterday
soon to be my new boss :headspin: , just officially been offered the job i've been hunting for with him!
spotted a few lines over the last couple of days, (i've done 300kms in 2 days and the car is boring me lol) gaves waves to them all, got none back, SCROOGES!!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/114/#findComment-1164162
haha, 300km in 2 days, i went from Canberra, Bathurst, Sydney, Bathurst back to Canberra in 2 days. about 1100km trip i think. half of it was on new wheels though.
Spotted a Silver R33 in the city, gave a wave but no reply.
https://www.sau.com.au/forums/topic/30059-spotted/page/114/#findComment-1164349
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
