spotted Jon (sxygtst) going past me as i turned into Ed's this morning, and the car is looking beautifull! and as i arrived, much to my delight, Jayce and Erica with the scooby and the GTR having a chat with Ed (not the cars, but the people were chatting) lol.
and hopefully in a few hours i'll have mine back with no heating drama's and possibly even a fixed boost controller, probably should have asked him to fix put on the new ytres i got but im enjoying the slicks at the moment.
https://www.sau.com.au/forums/topic/30059-spotted/page/130/#findComment-1208122
spotted both u guys just outside eds. thanks andrew hope ur problems fixed. i was in a bit of a rush late for work. i so wanted to sleep in but nothing :D:):P
https://www.sau.com.au/forums/topic/30059-spotted/page/130/#findComment-1208130
i did mean to ask, what do the plates mean? as-in what does Panadol stand for?
skyline city today in other news! spotted what appeared to be a silver 33GTR (maybe gtst just looked fatter somehow) either way, it was decked out and looked hot, going past hume at about 3:45pm.
black, wingless, R32 hammering through a roundabout near goldstein in chisolm, and various others at ed's i forgot about, oh and Jerry's S15 looking awesome at ed's again.
https://www.sau.com.au/forums/topic/30059-spotted/page/130/#findComment-1208961
Erindale was the place to be at lunchtime today.
Saw a grey 4 door getting Kingsleys. A black GTR entered just as I was leaving - then saw a Black GTST (I think) with red around the wheels on McBryde turning off towards Erindale Dr. They all looked like R32s to me but couldn't be sure.
https://www.sau.com.au/forums/topic/30059-spotted/page/130/#findComment-1210672
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
