spotted black R34 gtt outside new gel. was hot anyone off here
That’s still here??? last I heard he was selling it. The dude that owns it works their it is such a nice car the paint is perfect as you would expect. seems like a nice guy too though he wasn’t interested in sau
Note: why the **** is my spelling getting so bad i type it press post. then re-read it and its like wtf is this guy retarted :D
https://www.sau.com.au/forums/topic/30059-spotted/page/142/#findComment-1239072
spotted me sitting for 20 minutes out the back of the airport this morning waiting for the prince of denmark and mary's plane to arrive and them to leave god damn it did they ahve alot of cop cars and bikes looke dpretty cool and it was a decent excuse to miss 30 minutes of work :rant:
https://www.sau.com.au/forums/topic/30059-spotted/page/142/#findComment-1240706
Spotted GZ R33 at KFC gunghalin this arvo.
I cruised past to have another look, I was that 33 you were keeping an eye on when I came crawling past! lol...
Love that car, I want one.
Spotted Stevie.
Spotted Mick GTR today in Woden.
https://www.sau.com.au/forums/topic/30059-spotted/page/142/#findComment-1240816
spotted a sad looking red R32 GTS-T sitting on the side of the road opposite reid Tafe near the lights....
saw that to. poor thing. also spotted a grey r32 in fyshwick looked stock but was clean
Saw this car on the back of a tow truck in Belco today going up Nettleford St. looked very sad sitting on the back of the truck
Also spotted a white R33 parked next to me at Autobahn in belco.
https://www.sau.com.au/forums/topic/30059-spotted/page/142/#findComment-1241429
Stu spotted sexygtst on monaro highway last night about 9.30, plus a white one come flying past him on his motorbike, he didnt know who it was, just remembered the panadl plates.
mmmmmm monaro highway u sure it wasnt lanyon dr???
https://www.sau.com.au/forums/topic/30059-spotted/page/142/#findComment-1242172
I saw the same dudes doing laps in Yass, if you are on here I had the grey veilside r33 with 19's. It was about 2 weeks ago...
Spotted a bright pink R33 GTS-t with cromies with two blokes in it doing laps of Civic today at lunchtime. Had a P plate and had NSW plates.
Anyone here ?
J
https://www.sau.com.au/forums/topic/30059-spotted/page/142/#findComment-1242205
Spotted Jnr J's old beast at tech today
I saw it too, pulling into CIT off Haydon Drive Tuesday morning.
I wonder if he's discovered my interesting wiring yet! (A good 5 - 10m of speaker cable, 2 crossovers, an Air/Fuel mix tweaker & an AUX input for the stereo sitting under the carpet on the front passenger side!)
And I'm only getting my iPod now after selling the car... damn.
https://www.sau.com.au/forums/topic/30059-spotted/page/142/#findComment-1242365
    • Updating results following our SR20det project. Data collected form improves future turbocharger making and high flowing services. So far differences between G and GT series turbine wheels, we are in the process of making a new turbine, the aim is for better mid top range flow without gain too much lag.  Result is back to back comparison of G25-660 and GTX2867 spec turbochargers on the same car, nothing changed apart from turbocharger. Both tuned to knock limit from pump 98 fuel (US Ron93). GTX2867 was about 400RPM more responsive making 255rwkws while G25-660 made 17 extra Kws with wider spread of torque after 4500RPM finishing off at 272rwkws.
    • @GTSBoy i tried to jumper the wires and got the steering wheel light to come on which is right under the gear indication but that still doesnt come on.  Can it be an issue with my cluster?
    • Given that you have seen the dash indicator work briefly, then it would seem like you have a simple wiring problem. What happens when you simply jumper the wires on the "steering wheel switch"?
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
