Did anyone else spot the Nissan Micra club at Athlon Park today. i drove past and pulled in to check it out. There were about 20 Micras there, a good turnout for what i wouldn't really consider an enthusiasts car.
https://www.sau.com.au/forums/topic/30059-spotted/page/177/#findComment-1404610
oh tell me about it. i'll own a twin turbo 355 berlinetta one day i promise you all. lines are very very very nice, but i'll have the prancing horse thanks....
d
355? pfft, not even a 360? sorry mr "i can only afford the entry level spec poor mans ferrari" :)
Ferrari 550 Maranello Barchetta... now were talking :)
https://www.sau.com.au/forums/topic/30059-spotted/page/177/#findComment-1405391
>Actually I'm pretty sure it's the other way around dude.
I was going to say "I know, I was joking, I just thought it was a funny coincidence".
But then I got curious and decided to have a look...I went to:
http://www.barchetta.cc/All.Ferraris/ferra...mary/index.html
and couldn't find any Ferraris that had the four round tail lights before 1963 (which was when the first Skyline was produced with that tail light configuration). See:
http://history.jbskyline.net/
Can anyone shed some light?
https://www.sau.com.au/forums/topic/30059-spotted/page/177/#findComment-1406396
poor mans ferrari! i'll have you know i think the 355 is the most beautiful car ever so phhth right back at you!!! eight cylinders of full-house forged everything italiano with a couple of well-sized turbos, twin water to air cooling, m800/cdi/adl, dry sump, fully adjustable suspension, bracing/seam-welded chassis, custom carb fibre widebody w/underbody diffusers, puuuuuuurrrrrfect paint, a set of custom forged mg wheels, 8spot 400mm-ish/4spot 350mm-ish brembros fr/rear, ultra-exxy lightweight topshelf stereo (mcintosh/dynaudio/milbert/velodyne/tru tech/rainbow/apogee/phoenix gold -clicky- et al), hewland transaxle, interior made from the skin of magical, blessed and holy cows over perfectly shaped custom seats/dash/trims etc, number plates "FERRARI" and an "engineering approval certificate" from ferrari themselves... will do just nicely thankyou!!!
like i said at wakefield, you don't own a vspecII or n1 32 so you've got yourself a poor mans skyline!! ha! and sorry "mr... i can't afford dish volks" :chairshot :jump:
hehe
d
https://www.sau.com.au/forums/topic/30059-spotted/page/177/#findComment-1410500
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
