Spotted Erica or Jayce in the Forrester thismorning on Parkes way, also i think i passed Andrew(Veilside) going along the airport road. also saw about 4 other R33's, they're as common as excels almost these days.
https://www.sau.com.au/forums/topic/30059-spotted/page/192/#findComment-1501726
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
