Black R34 GTT turning into Wanniassa this evening, 7:40. Plates '34 GET' maybe?
Well spotted. Actually the plates are 34 GTT and thanks for the recognition. I'm new to Canberra (on a temporary posting from Cairns) and am keen to know who the best tuner of Power FC's are here in the bush capital.
Cheers
Muz
https://www.sau.com.au/forums/topic/30059-spotted/page/20/#findComment-785675
G'day Muz,
Welcome to Hicksville  :)
Hay a mate got his PFC Pro tuned by a bloke out in Queanbeyan and was really happy with the tune.  He does a road tune with all the gear etc.  If your interested I can get a name and number for you?
Cheers
J
Hi Jay,
That would be really appreciated.
Thanks heaps
Muz
https://www.sau.com.au/forums/topic/30059-spotted/page/20/#findComment-785773
Jakes not in QBN anymore, I think he's at Mitchell ACT.
Spotted that blackish 33 t with the blue/silver flame graphics over the front bonnet and gaurds on Kings HWY just after the twisty bit coming out of QBN.
But it was only a glimpse because our closing speed was around 250km/h. I made up about 150 of that!!!
Don't you just love the cool crisp air of Autumn.
https://www.sau.com.au/forums/topic/30059-spotted/page/20/#findComment-787934
yeah, thanks for comin up and sayin hello, good to see youve still got the skyline, and it sounded very nice as you left the servo with the exhaust :P the other guy was tribex off these forums too, we were cruising around causing havoc haha.
https://www.sau.com.au/forums/topic/30059-spotted/page/20/#findComment-789006
>not to see u again m8
Eh??
yeh sorry it was supposed to say nice to see u again mate. thanks amaru cant wait to see ur car running at its best again and tribex ride yummy. we should meet up next week if u want :wassup:
https://www.sau.com.au/forums/topic/30059-spotted/page/20/#findComment-789024
Muz - got that number for ya.
Blokes name is Peter and has a tuning shop out on Queanbeyhole. His moblie number is 0402 464 245.
If you ring up, tell him that Andrew, the bloke with a gunmetal R33 gave you his number.
Cheers
J
Hi Jay,
Thanks heaps
Muz
https://www.sau.com.au/forums/topic/30059-spotted/page/20/#findComment-791579
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
