forgot to mention, spotted amaru's r32 gtr forsale on scotts big boys toys website... well im pretty sure its his, has it been forsale for a while now or what?
Dayne
The company I used to work for designed the website, and it was put up to test the system out and make sure it worked ok and I just never removed it :)
https://www.sau.com.au/forums/topic/30059-spotted/page/211/#findComment-1615016
Ah okay.... wondered why i hadn't heard anything more about it!
Spotted a heapppp of skylines out last night, followed one that had DTS on the back of it for a while... also parked in the city next to a white r33 series II with chrome rims today, P plate, female driving:D
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/211/#findComment-1615256
i keep seeing a black 33 parked down the back of the erindale carpark, across the road from maccas, with a P plate and funny looking twin tip exhaust.....
also saw a yellow 33 at the 'mobil' roundabout at erindale yesterday arvo....
https://www.sau.com.au/forums/topic/30059-spotted/page/211/#findComment-1617103
i have a feeling thats graham as it also has the same front lip as his, ive spotted it before
https://www.sau.com.au/forums/topic/30059-spotted/page/211/#findComment-1617591
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
