Drivers side...
sorry what i meant was there are like 3 or 4 plugs if its one that causes the plastic to flap around get it fixed... however if its one that is held in place by another one i wouldnt worry to much... as i said though they are so cheap just go get one anyways
https://www.sau.com.au/forums/topic/30059-spotted/page/265/#findComment-1881237
Spotted a very nice white Stagea with an SAU sticker. I believe the owner is Marc at Discount Tyres in Belconnen.
The champion got me some sweet tyres for the S15 (R888s). Another SAU member helps me out! Great stuff!
Thanks CAMMA. Happy to help members where I can.
https://www.sau.com.au/forums/topic/30059-spotted/page/265/#findComment-1882680
Drove to work this morning behind Slither (most of the way) and another Black R33 GTST with what lokked like R33 GTR rims.
I dont know how that car can be daily driver Slither, it so stiffly sprung that I would have to wear a kidney belt to drive it.
https://www.sau.com.au/forums/topic/30059-spotted/page/265/#findComment-1884697
Spotted a white stagea going over that little bridge in fyswick thought it might have been marc then up at autobarn i spotted ib6ub9 going past and as i was leaving a black r33 s1.5 pulled up
Sorry Leech, not me. Stuck in Belconnen all morning then @ Gungahlin 'till about 2.00pm.
https://www.sau.com.au/forums/topic/30059-spotted/page/265/#findComment-1886346
hmm thats strange then i though their was only one white stag in canberra ??? either i just called a volvo a stag or maybe its a new one i think the later of the two :(
https://www.sau.com.au/forums/topic/30059-spotted/page/265/#findComment-1886409
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
