Spotted a gunmetal grey (?) R32 on a tow truck in belco last night.. didnt look like there was damage but then again i saw it for a split second.. any1z from here?
Advance spotted :) - me on friday going to check out my boss' new buy... RH9 with a completely rebuilt engine from Jun in japan! so excited :laugh:
https://www.sau.com.au/forums/topic/30059-spotted/page/283/#findComment-2001946
spotted what looked to be Nik's car outside of integra this morning
Go past today and it looks completely different again :D (if I could post picture I would, but it has no front end on it at the moment).
Should be an absolute weapon when its back on the road running around.
https://www.sau.com.au/forums/topic/30059-spotted/page/283/#findComment-2002645
get used to it. it'll be his car soon......
spotted a silver R33 going south along adelaide ave this arvo about 2ish. it was wingless with a sweet bodykit. got a wave, gave one back. your car looked awesome man, you on here?
https://www.sau.com.au/forums/topic/30059-spotted/page/283/#findComment-2006471
7:55pm: Silver R33 GT-R coming off the Parkway turning into Weston Creek
7:57pm: Yellow R34 25GT-t "NISSAN" on Hindmarsh Drive towards Woden
7:59pm: Silver R33 GT-R as above coming back out of Weston Creek :D
Disclaimer - times posted above are not exact, however are accurate to within about 1 minute :)
ALWAYS see a Skyline on Hindmarsh Drive when I'm out walking in the evening.....
https://www.sau.com.au/forums/topic/30059-spotted/page/283/#findComment-2006779
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
