spotted a yellow R34 in civic today...nsw plates... extreme hotness..
on friday I saw THE blue R34 GTR at Woden and I'm sure the driver saw me staring across at the lights like an idiot, somehow i don't feel worthy to wave to that car!! haha
and I saw him again a little later at Erindale, where I think he was picking up some guy in a suit who was waiting. Again I couldnt stop looking at it... this time I was walking back to my car... but i'm sure he's used to chicks staring :O
https://www.sau.com.au/forums/topic/30059-spotted/page/289/#findComment-2047619
Spotted......
Dark blue R32 GT-R in the Russell offices carpark with sexy as polished dished 18's at about 1pm
White R33 GT-R down in Grevellia Park at Auto Italia, next to a burgundy R33 GTS-25t
Leech's missus in his car on Cotter Road about 6:30pm heading over the Parkway towards Lyons
White R33 GTS-25t with bodykit & magz0rz coming off the parkway and then turning back onto it at Hindmarsh Drive at about 6:50
and yeh I think that's it
https://www.sau.com.au/forums/topic/30059-spotted/page/289/#findComment-2048811
spotted a hot 360 mondena, 355 F1 challenge and all kinds of mad italian cars at auto-italia. and there was a mad white R33 GTR in the car park....
also saw daves old GTR in tuggers near the hyperdome. gave a wave, got one back....
Edited by Frink
https://www.sau.com.au/forums/topic/30059-spotted/page/289/#findComment-2049557
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
