hope it wasn't the yellow supra i see around town - i've always thought it was kinda nice to look at in a ricey sort of way. too huge a body kit for my taste, but quite striking.
spotted a white r33 with DTS written down the side tonight at blockbuster woden. not sure if he's a local coz he started going out the 'in' lane from hindmarsh drive.
https://www.sau.com.au/forums/topic/30059-spotted/page/294/#findComment-2074294
not a skyline, but last night i spotted a yellow supra mount a gutter and then get stuck on the median strip between the servo and shops at kaleen, took them about 45 mins to figure out how to get it off there, the body kit didnt look too good after
sounds like the yellow non turbo one with the veilside kit i see frequently at ANU. P plater non turbo, driven by an international student guy
yeh, a wee bit too much rice for my liking
https://www.sau.com.au/forums/topic/30059-spotted/page/294/#findComment-2074402
I think everyone knows that supra... I see it all the time. From a distance it looked allright. Get up close and it looks pretty average (lots of cracks and scrapes all over the place)... Beaching it probably hasn't helped it any either :
Edited by Sauce
https://www.sau.com.au/forums/topic/30059-spotted/page/294/#findComment-2074476
yep hes a local, i did a CIT welding course with him. he works at DTS
https://www.sau.com.au/forums/topic/30059-spotted/page/294/#findComment-2075105
that was me..
u should have said hi! you're the guy who knows scotty right? I remember tallking to you in the south coast thread a long time ago ;)
i would of said gday, but i wasnt too sure.. just seeing the sau sticker and a chick in a wine 33, was to sure...
i was in my daily (charade) just got off that big roundabout at kinston doing reverse nuts :thumbsup:
yer, scottys in wollongong these days, saw him up there about a month and half ago in my rotor... couldnt believe it!!!
such a small world
https://www.sau.com.au/forums/topic/30059-spotted/page/294/#findComment-2076522
yep thats the one, think he was gonna try swinging a nut in the carpark afterwards, kinda didnt work
https://www.sau.com.au/forums/topic/30059-spotted/page/294/#findComment-2076562
Spotted Thursday morn': a de-winged R32 with a "work-in-progress" vented bonnet heading towards Queanbo' on Lanyon Drive. Looked like the car will turn out nice! Also spotted this morning one of the angriest sounding R31's I've ever seen at Macca's in Fyshwick about 8.30. Black 2 door;anyone on here(jeez,I hope so)?!?
https://www.sau.com.au/forums/topic/30059-spotted/page/294/#findComment-2077442
There's a guy with a black 2 door 31 that works at Domayne in Fyshwick, perhaps that's the one you saw.
You want an angry 31 Jayce, keep a keen lookout for a gunmetal Aussie 4 door that has a habit of getting sideways under boost (Frink, Bullet31 and Stinkypoo know which car I'm talking about)
https://www.sau.com.au/forums/topic/30059-spotted/page/294/#findComment-2077734
Now I'm interested!
https://www.sau.com.au/forums/topic/30059-spotted/page/294/#findComment-2077835
Is this the one that was out with you lot on the night of the big RJ's meet about 2-3 weeks ago??
https://www.sau.com.au/forums/topic/30059-spotted/page/294/#findComment-2077878
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
