Spotted me "discovering the pluses of buses" for the first time in 5 years over the past 2 weeks, gotta admit, its fkn awesome, does make for a long day when working 7-5, but its alright.
spotted a white Stagea at the snow sale at epic yesterday, had wheels, looked lowered, also spotted a white R33 sII in civic today, had blue graphics on the side and a big GT-wing.
https://www.sau.com.au/forums/topic/30059-spotted/page/310/#findComment-2266441
Stopped at an intersection and had a chat to a maroon 33 (with gold bbs mags).
You said you were a member here and that your user name started with R but I can't remember the name.
gday Mivec... how r u mate??? been a while since i came here... hows everything....your car looks tight mate...
https://www.sau.com.au/forums/topic/30059-spotted/page/310/#findComment-2271091
Hey man I'm tops.....I looked left and saw your massive front mount and thought "wowa, big mutha comin through!"
Ride looked nice as dude, your gold rims match the maroon perfectly.
https://www.sau.com.au/forums/topic/30059-spotted/page/310/#findComment-2272048
First third of neon sign on the Australian Customs building in Civic blacked out.
Reads: ALIAN CUSTOMS
Intergalactic border patrol protecting you from the scum of the universe..
:P Was there two dudes,all in black,waving some stick with a red li... :):D
https://www.sau.com.au/forums/topic/30059-spotted/page/310/#findComment-2272082
Spotted me out for a drive and getting pulled over my the boys in blue for a breath test and car check the whole thing lasted 45min....
They asked if it was factory turbo? YES
They asked if it had a Cat converter? YES
They asked is I was a streat racer? NO
They asked if I was a drifter? NO
Then:
Tyre check....ok
Engine check...ok????
Lights, indicators, horn...ok
OK son thanks for your time, drive safe......
Great!
I'm so happy my Passage GT comes factory with 300kw RB25DET with Intercooler, pod and BOV cuz otherwise I would have been in big shit!
G
https://www.sau.com.au/forums/topic/30059-spotted/page/310/#findComment-2286796
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
