I saw the both of you, but never at a point where I could wave.
Mladz I saw you leaving Banks on the way up.....Leigh I saw you leaving, wasn't sure if it was you cos the wheels looked like 5 spokes and not the 34 rims I think you have.
Also got a wave from a dude in a white 32GTR at the Erindale roundabout.
https://www.sau.com.au/forums/topic/30059-spotted/page/360/#findComment-2733965
I didnt see you at banks but I saw you at the McKillop formal looking ful sik :)
https://www.sau.com.au/forums/topic/30059-spotted/page/360/#findComment-2734721
Hey that was me, I was going around the round about noticing how huge the car's mouth was. impressive.
followed a white R33 S1 GTST today to work, YCY-24Q pretty clean and nice dished rims.
Hope to spot most of you guys tomorrow at the BBQ.
https://www.sau.com.au/forums/topic/30059-spotted/page/360/#findComment-2735512
spotted a silver 33 with veilside kit near gunghalin and a maroon series 1 yesterday around tuggers.
Also who was it in mooseheads last night that pulled me aside haha. I was heading home pissed as all buggery and then someone grabbed me and goes "hey your alex, you bought that car off ebay" I was shitting myself, didnt know what was going on.
https://www.sau.com.au/forums/topic/30059-spotted/page/360/#findComment-2738715
mmmmmmmmmmmmmmmmmm very tasty jayce... i will take one please :P
Yup;no prob's! From what I heard,a 10% deposit should secure you one of the 20 in the world...which,from some reports is around $33,000 for said 10%!
Pity they're all sold,really...
https://www.sau.com.au/forums/topic/30059-spotted/page/360/#findComment-2739363
Spotted GTR-003 pulled over by thre police last night around 12:15am on the parkway, hopefully nothing too bad.
and then around 12:25am Red R33 GTS-T having a play with a p-plated commodore followed by some 4X4 foloowed by a Gold WRX and then some other car all quite fast on hindmarsh drive near weston.
https://www.sau.com.au/forums/topic/30059-spotted/page/360/#findComment-2743708
spotted daves old blue R32 GTR yesterday in the stupid traffic going across northbourne.
i swear if i don't see people move as soon as the light goes green, or people who sit well under the speed limit when there's no one in front of them will feel the back of my club lock if they do that shit in peak hour!
https://www.sau.com.au/forums/topic/30059-spotted/page/360/#findComment-2744398
spotted like 1000 skylines in the space of a hour or two (well it was really only 7 or so)
A silver r33 heading down towards the roundabout at erindale 5:25ish
then at baseball training 5:30 - 7ish (Viking Park, Erindale) i noticed
2 silver r33's, black r33, white r32, black r32 and on the way home a silver r33 with nsw plates
https://www.sau.com.au/forums/topic/30059-spotted/page/360/#findComment-2747813
    • @GTSBoy i tried to jumper the wires and got the steering wheel light to come on which is right under the gear indication but that still doesnt come on.  Can it be an issue with my cluster?
    • Given that you have seen the dash indicator work briefly, then it would seem like you have a simple wiring problem. What happens when you simply jumper the wires on the "steering wheel switch"?
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
    • Maybe I should have written that a bit better lol. I did come 8th last in English at school during the HSC, ironically spent 2 decades reading/writing specifications and contracts in IT 😂
