I spotted the yellow 332.. with a massively wide body on the back of a tow truck heading into belco from civic... after the tunnel.. niiiice..
yer thats fatass its nice as i think glen from esp bought the rolling chassis wit no motor from the previous owner. it used to have a 1000 hp motor in it
https://www.sau.com.au/forums/topic/30059-spotted/page/412/#findComment-3146012
Spotted mine with its hood up in the middle of hindmarsh drive with a blown cooler pipe yesterday >__< How bloody annoying that was...
thats fkn annoying hey! if you dont have tools best you can do is just jam it back on and hope that it stays on until you get home/to mates place.
https://www.sau.com.au/forums/topic/30059-spotted/page/412/#findComment-3148315
Spotted a silver 33 with its hood up in my girlfriends st in Calwell on the weekend. <snip> no addresses please dude! <snip>
That was me learning the hard way that you should always make sure the o-ring from the old oil filter hasn't stuck to the engine block, before you screw on the new filter. 4 litres of brand new Castrol Edge on the driveway, and much swearing that you probably heard from your GF's place.
Car was sent packing to the nature strip in disgrace.
Next time, can I come down to your GF's and change the oil on the new paving? :cheers:
https://www.sau.com.au/forums/topic/30059-spotted/page/412/#findComment-3151445
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
