White 34 sedan (Barton Hwy) around 4pm and black 33 heading north on parkway around 2pm yesterday
Black 33 might've been me, right before i got pulled over for an expired rego label. Funnily enough, i'd paid for rego but hadn't replaced the sticker yet (since the last one had required a razor to get off... cheap crappy stickers) and once the cop checked the car had rego, he pretty much told me to get lost. Didn't even say anything like 'make sure you put your new label on.'
Makes me wonder if the emphasis is on road safety or revenue... hmmm...
https://www.sau.com.au/forums/topic/30059-spotted/page/443/#findComment-3410084
