Saw LadyBytes R32 in civic today. Creative parking btw.
Your federals are going to wear out if you keep using them for normal street driving though :D
Not so creative... I had Steady Eddy with me... he's good for getting the good car parks LOL actually, I have secure parking at work and felt nervous with it out there.
Federals are good for street... soft but not too soft... I think they're good for around 13000ish k's
https://www.sau.com.au/forums/topic/30059-spotted/page/444/#findComment-3415702
In an R32 GTR you can expect about the 12 - 13,000km from 595RS, which isnt to bad considering how soft they are, but the problem is that your slowly degrading the tread compound by driving them cold, they are designed to be driven hot, so the more you drive them on the street the less heat cycles your getting into them and in turn you might find that they go a little bit hard after a couple of thousand km's...
That said, if you wear them out you will need to buy more, so go for it, I'll be here when you need another set :D
https://www.sau.com.au/forums/topic/30059-spotted/page/444/#findComment-3416834
Spotted a whole bunch of police cadets learning how to direct traffic at the melrose drive intersection, opposite mcgrath ford in woden around 2pm today lol :D Spotted a Black r34 gtt later in gungahlin, too late to wave though.
https://www.sau.com.au/forums/topic/30059-spotted/page/444/#findComment-3416854
did you say hi to my mate for me? He'd be the one with the giant "i'm a fu*kstick" stamped on his forehead.
https://www.sau.com.au/forums/topic/30059-spotted/page/444/#findComment-3416885
Funny that, went past at 2:20ish and they were gone when they were actually needed with a ford broken down at the intersection causing all sorts of chaos with idiots cutting lanes to save a precious minute..
Also saw a wrx pinned by an undercover VZ just down the road too.
https://www.sau.com.au/forums/topic/30059-spotted/page/444/#findComment-3416905
Nah was trying to drive as "quietly" as possible past them lol, sux they weren't there later by the sounds of it.
https://www.sau.com.au/forums/topic/30059-spotted/page/444/#findComment-3416962
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
