haha i spotted a maroon Camry on the same road tonight
was kinda half up an embankment with the door hanging open, couldn't see what damage it had exactly
Maybe it was a Camry...dunno was making sure i didnt end up parked next to it.
https://www.sau.com.au/forums/topic/30059-spotted/page/473/#findComment-3739574
sure was.. dealing with traffic destined and from Quenbeayan... it's like being back in Sydney traffic again!
what's your ride?
Hey mate, havn't been able to log in for a bit...
LOL...my ride... unfortunately atm... it's the fabled Starlet... (you might have heard about it if you have read the forums recently). Saving for a Line.
Lost my old car cause of a problem with the brakes.... long story.
https://www.sau.com.au/forums/topic/30059-spotted/page/473/#findComment-3741884
saw donnon in hoyts last night and on my way out i saw 2 maroon r33s n i think it was the mighty starlet parked behind my car, black with a skyline performance sticker on the back. was round 9:30 last night
yea.. that starlet is scary.. especially that 54kw... it put us to shame didnt it ZCR.
also saw a maroon 32 gtr near nat cap motors in belco and a silver 33 on the dyno at dynotune yesterday at about 5pm
https://www.sau.com.au/forums/topic/30059-spotted/page/473/#findComment-3746043
Ive also seen that R33, I dont like the bonnet scoop much but the rest of the kit + wheels look really good...
Each to their own aswell, some people might think that white R33 Gtst's with Abflug kits look horrible :)... Thats why we're all individuals.
https://www.sau.com.au/forums/topic/30059-spotted/page/473/#findComment-3749050
Im not saying that youre not allowed to voice your opinion, what Im saying is that if someone said to you that something about your car looks gay you would probably be quite offended...
Perhaps a better choice of words next time Shawn? :)
https://www.sau.com.au/forums/topic/30059-spotted/page/473/#findComment-3749106
gave a wave to/ got a wave from a white r33 yesterday at about 13:00 going the opposite direction along beasley street.
also waved at sauce driving along nomad drive near the airport but i was in a work car.
https://www.sau.com.au/forums/topic/30059-spotted/page/473/#findComment-3749357
That Starlet is very scary... especially when this face is peering over the steering wheel :O
Hey ZCR, yeah we were out seeing Vantage Point... I saw you too! :huh:
HAHAHAHA Michelle, you are a funny woman! I laughed SO hard when I saw that post! Did Mark take the photo of Reece?
... I'm thinking about getting the chassis reinforced/seem welded... so much power! :ermm: It's just bending every time I put my foot down! :)
https://www.sau.com.au/forums/topic/30059-spotted/page/473/#findComment-3749622
Oops :laugh: Sorry about that, wasn't being a snob! When? And what were you in? I was probably completely zoned out if it was after work haha
https://www.sau.com.au/forums/topic/30059-spotted/page/473/#findComment-3751261
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
