Spotted a Black / Dark Green (was hard to tell being dark) R34 GTR NUR VSPEC in Kingston last night at approximately 9pm. Had a good chat with the owner about his car, and was very impressed... good to meet you buddy!
G.
I saw that car there today and I was creaming my pants :D That is one sweet GTR!
Than 30sec down the road, a Silver R33 GTST..?? i think
Than another 30sec down the road, another Silver R33 but a GTR this time.
SWEEEEEEEET
Ps: asshole and wanker - just cos Shell said we could ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/492/#findComment-4023126
i think i spotted naughtyruski this morning in civic
Yep that would have been me. Where abouts did you see me?
Just had an awesome weekend boosting around Wagga, went up there to get smashed with the returning Uni students. (used to go there) First highway cruise in the skyline. Loved it. Bit thirsty but who cares. I didnt buy it for saving fuel =)
Edited by naughtyruski
https://www.sau.com.au/forums/topic/30059-spotted/page/492/#findComment-4027625
i was driving my red 33 s3 on marcus clarke st when you drove the other way
https://www.sau.com.au/forums/topic/30059-spotted/page/492/#findComment-4027902
ahuh I remember seeing a red skyline around there, you have a trojan sticker? Sorry I didnt wave. I dont know many members personally yet, hopefully will see you most of you at this weekends meets.
https://www.sau.com.au/forums/topic/30059-spotted/page/492/#findComment-4027934
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
