Spotted a shit load (and I mean a shit load) of Skylines in Civic/Braddon last
night (JohnnyR31 & I went for a bit of a drive)
Among them.....
Black R34 25GT-t sitting in the servo in Braddon
White R32 GT-R in front of the R34
White R32 GT-R came into the servo for a few minutes
Red/Silver R31 Silhouette parked in carpark behind Caltex servo
Blue R32 GTS-t with rego plates 'MARK' came into the servo
Silver R33 GT-R at hospital traffic lights
Gunmetal grey R33 GTS-25t went through the Hindmarsh Dr/Melrose Dr traffic lights a few times
White R32 GTS-t at the same set of lights
White R33 GTS-25t with black wheels again at same lights
And today in Yarralumla a black/gunmetal R32 GT-R, I gave a little wave & I think I got a nod back
https://www.sau.com.au/forums/topic/30059-spotted/page/59/#findComment-1008940
spotted myself getting own3d this morning by a new worked SS ute.....unbeleivably pissed off, it was neck and neck from the lights but we got to a round about and he had the inside lane so i had to slow down alot more and turn more being on the outside. im so sick of running stock boost!!! i would have drilled him running if i was running anything over 10pound, i'll have to be pateint till i get my ebc and fmic i guess.
https://www.sau.com.au/forums/topic/30059-spotted/page/59/#findComment-1011091
What? That's outrageous behaviour and unacceptable.
You mean you didn't draft him through the roundabout? Should've tucked in behind and used revs to punch out ahead through the other side...heh heh bring on the boost.
https://www.sau.com.au/forums/topic/30059-spotted/page/59/#findComment-1011815
hot driver? nah couldnt have been supafly, cause i wasnt driving his car on sunday
:wassup:
while were bringing up old spotteds, i spotted a white R31 on sunday just after dropping angus off in chifley. it broke for a roundabout and the left taillight lit-up saying skyline, and the right one said silhouette(sp?) looked cool, even though i dont really like R31's
https://www.sau.com.au/forums/topic/30059-spotted/page/59/#findComment-1012745
:wassup:
That's a friend of mine and angus'. That Silhouette actually goes very hard for what it is...... just something about it
https://www.sau.com.au/forums/topic/30059-spotted/page/59/#findComment-1013628
Spotted a couple of flash skylines today,
A black R32 with fire details painted on the front end driving through Kaleen
A silver R33 with stripes like that of the R34 in 2 Rice 2 Furious in Dickson
https://www.sau.com.au/forums/topic/30059-spotted/page/59/#findComment-1013856
    • Maybe I also should have wrote that a bit better lol. I did come 8th last in English at school during the HSC, ironically spent 2 decades reading/writing specifications and contracts in IT 😂
    • Right, but that's in-cylinder, there's the interaction between that and the TWC which complicates things. Pulling out timing to reduce NOx is a strategy I saw in transitional emissions vehicles like stuff from 1974 or so. The two inlet runner system is interesting but I'm not sure it makes a huge difference as far as emissions goes, is it a tumble valve? I've seen stuff like that even in cars from the late 80s.
    • Hello all,   so i recently swapped out my rb20de neo with an rb25de neo( engine,transmission, wiring and the diff everything) but i just cant get the gear indication light on the dash to work when i switch to tiptronic mode. Note there is a steering wheel switch beside the shifter and i dont have that. I did notice yesterday while switching to tiptronic that the indicator on the dash started to work but it didn't afterwards. Does anyone know how this actually works? Or do i still need that steering wheel switch to be connected and on for that gear indicator to work?
    • Hence why I said earlier that I don't think the turbo Neos ever would have actually qualified as an LEV. I suspect the only actual LEVs that came out of Nissan were the NA Neos. Still call them all Neos. They all stil have the Neo-ness. Just that they don't all qualify as as LEVs.
    • It will give gains, but you wont hit 600 It will give gains but it wont get you to 600 imo. You will also sacrifice low down and you will be adding extra volume if you port match it, more so if you port the plenum runners depending and how its done I think the only time youre going to see about 100hp gains is if the car is making well over 1k kw I do have a spare set that I was going to test with, but i dont actually think there is anything worth getting going larger. I did a fair few S14/S15 and the standard TB is fairly small, I went to 60 and in some cases 64mm which is significant over the stock unit. You can also get some weird ratio changes. I think 20kw will be a stretch on a roller dyno. If I had it apart I might mill the shafts a little and not expect much, I think the stock size is still pretty good for a street/track car even with larger capacity. I might change diameter it if its a drag only car
