Spotted Kat today from Gungahlin lights up, then up the barton highway. I was on the green ninja.
Love the sound of your motor. Gave you a wave but you wouldnt have seen me through the mirror visor.
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5104287
Spotted a white 32 4 door with a black boot and fuel cap cover driving from holy family all the way to Gordon direction driving like a granny around corners but would give it a hit (if they manage to be in the correct gear exiting the corner) on the short straight bits...then I believe a black 34 was up my arse while I followed the 32 who then followed them further when I turned off.
And wow my grammer is terrible haha
ps I was in the black ute
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5106075
Blue 34 GTR on Yamba drive near the hospital, was stuck a couple of cars back and couldn't get in closer for the wave :blush: also I believe ZANE this morning as he went up the Hindmarsh exit ramp from Monaro heading south...I was on other wise of the highway
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5106330
Saw a charcoal grey R32 GTS-t at the RTA carpark in Queanbeyan today (that carpark is designed to break cars i swear) female driver, looked pretty stock save for the exhaust. If the owner is on here i was parked next to you in the white 260Z.
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5107785
Blue 34 GTR on Yamba drive near the hospital, was stuck a couple of cars back and couldn't get in closer for the wave :P also I believe ZANE this morning as he went up the Hindmarsh exit ramp from Monaro heading south...I was on other wise of the highway
yay i got spotted!!! but i didn't even see you lol
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5108256
That was my car but a friend is borrowing it due to hers overheating.
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5110635
Nah mines silver and no GTR kit. I only go that way if Captains Flat Road has been freshly grated, otherwise I go the long way around or I take my falcon.
I have seen yours, but not for a long time. do you go out that way often?
yeah, once you are past the dirt section out the back of captains flat, the road is awesome :down: long straight tarmac right through to braidwood! it cuts my travel time to the coast down if I go that way - just need the dirt section sealed...
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5110920
I used to, not so much anymore. I normally take my green EL falcon but sometimes I just can't be bothered putting up with slow. The dirt road is REALLY fun if it's grated but the moment it rains it's just. Not good. I used to drive that road every night at about 1am. I used to get very sideways, it helps having your headlights where your going, rather than off the road.
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5111764
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
