spotted a metalic pink R33 coming outta UAC this evening, chick driver
You mean UC? If so it was Me (Melly-too lazy to log in as me lol) I always spot heaps of skylines on my way too and from work in Mitchell and have seen a white 34 at Uni a few times.
https://www.sau.com.au/forums/topic/30059-spotted/page/611/#findComment-5118330
Spotted white 33 GTSt on Deamer in Richardson, was driving down the hill. I was on my bike out the front of my house - gave a wave but don't think you saw me...then saw what I think to be the same car up the other end of the street....had a SAU sticker on the windshield so I know you're here somewhere :D
https://www.sau.com.au/forums/topic/30059-spotted/page/611/#findComment-5123784
hey im a n00b on this forum, just wondering if you guys still meet at the museum? or if you do any friday night cruising. i remember cruising out to uriarra tracking station with you guys a few years back in a mates car. Ive just bought it off him.
https://www.sau.com.au/forums/topic/30059-spotted/page/611/#findComment-5129413
Try this thread:
http://www.skylinesaustralia.com/forums/Fr...&start=1920
If you search in there you should be able to find the location of the meet
https://www.sau.com.au/forums/topic/30059-spotted/page/611/#findComment-5129686
Spotted a black R33 down near Tuggies pool, waved out the window, got snobbed :(
Also spotted another black R33 which I thought was the first one again so I didn't wave :cool: so if you have blonde/surfie hair and drive a black R33, sorry for no waves :blush:
Also as I was leaving the Hyperdome, spotted a guy in a Datto 1200 ute looking at my car instead of where he was going and smashing into a gutter :P (ok, probably not funny, but meh)
https://www.sau.com.au/forums/topic/30059-spotted/page/611/#findComment-5130684
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
