Inline did my rack bushes... Which ended up putting my HICAS way off (weird feeling it coming on in a straight line!). So I had it removed or rather locked with a Tomei kit... I thought it made the steering heavier, particularly at lower speeds, but decided it was in my head LOL. Now I'm not so sure!
https://www.sau.com.au/forums/topic/30059-spotted/page/619/#findComment-5197101
You need the fins removed from the rear section of your ps pump
https://www.sau.com.au/forums/topic/30059-spotted/page/619/#findComment-5198635
Spotted a black R33 GTS-T turning into Mitchell from Gungahlin Drive this morning.
And further down spotted what looked like a purple R33 of some description. Couldn't see the whole car with the big grey wall in the middle.
https://www.sau.com.au/forums/topic/30059-spotted/page/619/#findComment-5201014
not an easy job. best done when the turbos are off (that;s when I did mine). when you are doing it, its best to remove the enitre rear pump wheel that holds the fins, the rear steering lines and the Hicas controller that sits on the chassis rail under the plenum. you'd e surprised the difference this makes when changing an oil filter!
the steering loading up can be caused by the steering wheel not being aligned properly with the locator, or you may need to reset the system (process of reversing a couple of meters, then the same forward - there is a DIY on here somewhere).
https://www.sau.com.au/forums/topic/30059-spotted/page/619/#findComment-5201035
Spotted the Purple R33 turning into Mitchell! And spotted me driving my Grey / Black R33 in traffic on the GDE!
https://www.sau.com.au/forums/topic/30059-spotted/page/619/#findComment-5201130
Passed a black 34 at the bottom of Coulter Drive on Sunday night ~11.50pm... they pulled off into Weetangera afterwards. Anyone on here? :) Didn't think to look if it was a GTR or not, but I'm curious!
Yeahh, that was me, its a GT-T :D you were the Grey 33 right ?
https://www.sau.com.au/forums/topic/30059-spotted/page/619/#findComment-5204017
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
