Spotted!!
Shell
Spotted me finally driving my Skyline for the first time in 7-8 weeks.
Also spotted a white 32 GTR turning into Bonython at 0830 this morning.
know how that feels. Mine hasn't been on the road many weeks since I had it off for about 6 months. Will have it off again soon for more. Sucks but it's usually for a good cause. Why was yours out of action?
Spotted a dark coloured R33 pass me on Monaro Hwy with non functioning headlights (taillights were working, didn't notice any parkers, which would have been useless anyway)
hahahahahahahahaha oh son of rajab, yeah but I don't take note of anything that isn't a nissan :)
But yeah I get zoned bad sometimes lol, focusing on all those irritating rattles and squeaks
Harsh, but i'll still beat you round a track..
Sounded good from the outside though, no rattles and squeaks noticeable.
something front-left squeaks, might be a bush but more than likely the front bar rubbing on the cooler....on that note who can help me remount it? I can't work out where the mount point are to fix it :ermm: i r nub
And yes, you could probably beat me around a track driving whatever you want :)
spotted 3 new skylines in 2 days. that light blue one on thursday on the monaro, yesterday a white one on the monaro and a silver one last night on sulwood. dunno if they are V35s or 350GTs first two were side on and couldnt get close enough the the silver one was too wet. also a maroon R32 leaving fyshwick on newcastle going onto hindmarsh about 5.30 yesterday arvo
i may have been on sulwood in a silver v35 :D
i may have been on sulwood in a silver v35 :)
was friday night 9.30-10pm. turned from athlon from woden...
spotted shell on hindmarsh outside the hospital 2.15ish, once again eyes only on the road...
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
