Spotted!!
Shell
spotted shell at autobarn today
in the carpark? Or you work there?
Was getting 11tybillion parts for the R33 to get her ready for Wakie track day!! :banana:
Spotted a Vspec r32 gtr in the civic/duntroon area around 2:30 ish. Think they spotted me as well, car looked nice.
Thanks. Yeah spotted you too. Gave you a wave but i think you were concentrating on the road and looked the other way the same time i waved.
Spotted naughtyruski in the front office of my work today, didn't get a chance to say hi
Haha, i didnt even see you there. Remembered you worked there, but figured you were hiding out the back. Was just buying fresh Vacuum hoses for a new electronic boost controller
spotted Shells car in the latest HPI. Id say it'll be in newsagents in another week or so.
oh yayy! Been waiting for the Show N Shine issue to come out, I knew it was the next one!
Yeah i was pretty busy lol, you fitted the boost controller yet?
Spotted wal32r (I think! or a very similar car!) on Ginninderra Drive tonight at about 8pm
Ginninderra dr sounds like me lol, cool if it was i havent been spotted yet haha, were you in the 34? Dont see how i could miss it
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
