Thanks :) Mick,
The Cayman ran up the back of a Commie which went up the back of a Suzuki which went into the back of Matt's R33 GT-R.
It looks like minor cosmetic damage only. Reo/bever panel will need replacement as well as the bar. So not too much.
Matt will probably be offloading the GT-R soon, as he's buying my R34 GT-R. I'm committing myself to a Bayside Blue VS2.
Nissans are under my skin a bit more than Matt, as he's still quite keen on Beemers too.
What comments (criticisms as well as compliments) did your boys have about the 21st? Different hairstyles back in the early 90s eh?
The new toy sounds very nice Terry, and Matt is a lucky bugger to be getting his hands on your R34 GT-R (I am jealous).
The boys were very impressed how the R32s were untouchable at Bathurst in 91 and 92.
They had a great time at the 21st being around all those JDM Skylines, and very much enjoyed the cruise and want to do another soon. Ben is putting awide body kit on the Silvia, so will look quite different shortly. They (boys) are trying to convince me to sell the GTT and move up to a R34 GT-R (not much convincing required there I'll tell ya)....soon....soon.
https://www.sau.com.au/forums/topic/30059-spotted/page/639/#findComment-5516444
rofl yes I think so. Looks funneh.
I've also seen a bright orange 33 getting around tuggers area with some blonde chick driving...hmm
Also spotted a black (?) 33 headed south on drakeford yesterday pulling up to the roundabout at isabelle drive...gave a wave and got one back :)
https://www.sau.com.au/forums/topic/30059-spotted/page/639/#findComment-5520033
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
