I'm sorry ... I should intro myself,
My names Bill, I've been a Skyline fan for many years and have owned them for 10 years having a gunmetal S1 R33 before the 34. I moved to this area abot 3 years ago and have been a regular 'guest' to this site to keep an eye on whats happening around the ACT.
I couldn't resist Zebra's post so I registered and said hi, I've seen many of you on the road in my travels, my work keeps me running around town a bit so you'll probably see the car around. As I said I usually give a wave if I see you early enough. B..
https://www.sau.com.au/forums/topic/30059-spotted/page/640/#findComment-5520941
hahaha yeah a compliment!! I'm not really good at thieving :blink:
I really want dark bronze rims, they'd look wicked with the yellow :)
They would Shell, bronze was made to go with yellow, mine as I said was done by Wicked Wheels and when in the sun (and clean) they have a gold fleck through the bronze ...
https://www.sau.com.au/forums/topic/30059-spotted/page/640/#findComment-5521002
I'm torn between getting mine resprayed (and having the gutter rash fked off lol)
Could only really get them done black....white R33 GT-R wheels would like ghey.
I wouldn't mind a set of those multi spoke fluoro yellow wheels in 18 though.... :D
https://www.sau.com.au/forums/topic/30059-spotted/page/640/#findComment-5521423
Nah, sell 'em and buy mine :-D
https://www.sau.com.au/forums/topic/30059-spotted/page/640/#findComment-5521458
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
