Yay Gym :wub: Which Gym?? :yes:
Nvermind, read back, Anytime Tuggerz... I might see you guys there, I go to different anytime gyms depending on my mood lol :)
Spotted a green 32 in Fyshwick (see it almost daily), also a pretty blue 33 in Fyshwick and a black 34 in Fyshwick :)
im there after work.. mainly between 430-530 onwards...
spotted a yellow r33 in the tuggers KFC drive thru around 715 tonight.. ohm nom nom nom!
https://www.sau.com.au/forums/topic/30059-spotted/page/690/#findComment-6032973
Spotted a silver R33 in my driveway at work in Fyshwick (on Gladstone street near the gun shop) spotted ZCR on Parkes Way (Yes, it is relevant as I was in my skyline for once and I saw him somewhere other than at home) got beeped at by a maroon r33 on Canberra ave right near the roadworks at the bridge, they were stopped at the lights heading the other way sorry I saw you late whoever it was so didn't wave...
https://www.sau.com.au/forums/topic/30059-spotted/page/690/#findComment-6034276
Ya I'm working on it :P Plan to go less stretch and a bit less rear camber. Should fill the guards up a bit more. Right now working on power and getting a new engine back into my pig :)
Is that the Pearl White one?
If so....mint car...I followed you into Woden Westfield one evening...was popping flames out the pipe just idling around...but I must say needs MOAR tyre under the bum....wheels are right....but I hate tyre stretch lol
https://www.sau.com.au/forums/topic/30059-spotted/page/690/#findComment-6037067
Spotted a dark blue R33 with a white front quarter panel at Wanniassa shops about 2pm
And forgot: spotted a blue(?) wingless R34 with LED tailights about midnight on Hindmarsh Drive about midnight the other night, looked really good.
https://www.sau.com.au/forums/topic/30059-spotted/page/690/#findComment-6037776
Yeah there's a few like that. I don't tend to wave first unless I "know" the car/people.... or I'm flying past and a wave out the window is easy to do and who cares if they wave back. Sitting at the lights just leads to awkwardness if they don't wave back :D
I'll always wave back if they wave first though!
https://www.sau.com.au/forums/topic/30059-spotted/page/690/#findComment-6037878
just sit there staring at them blankly if they don't wave back hahahaha
So I spotted a dude in a Rodeo ute or something next to me at the lights in tuggers today frantically searching his pocket for his phone to take a pic of my newly applied stickers (courtesy of Clutch, wherever that f**ker has disappeared to):
He thought it was awesome hahaha
https://www.sau.com.au/forums/topic/30059-spotted/page/690/#findComment-6037894
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
