spotted myself booking the GT-R in to ultimate tunes to get it running.....=(
Also spotted a black rsfour stagea in conder this morning.
Spotted a black R32 GTR on betty maloney cr near the park... on friday.
anddddddd spotted that bloody R34 v-spec 2 in tuggers kmart carpark.its there to tease me!
https://www.sau.com.au/forums/topic/30059-spotted/page/743/#findComment-6383315
You cant really called that a spot when you have 2 skylines in the drive way.
"Oh i spotted my stagea sitting in my drive way again and again" lol
https://www.sau.com.au/forums/topic/30059-spotted/page/743/#findComment-6383828
Spotted a purple 33 at the units then came around the corner and saw a Bayside blue R34 GTR,
I got out to open the garage and spotted an R32 GTR.
As I closed the roller door I saw a Silver 34 GTT parked in my driveway
Just taking the piss :D
Oh and that Bayside Blue 34GTR you spot at tuggers lives in this complex too.
https://www.sau.com.au/forums/topic/30059-spotted/page/743/#findComment-6384075
spotted myself limping home in the Stagea.. I think I may need new coilpacks.
You guys are hillarious!!!!
Whens the next chance for us all to catch up?
https://www.sau.com.au/forums/topic/30059-spotted/page/743/#findComment-6384831
Spotted Azathoth going past EPIC today 1:50pm ish.
(I was in the work truck.)
Spotted the RS4-S Black Stag with Green Wheels on Thursday on William Hovell at 8:50 ish.
Shortly after that, saw a nice R34 GTR Champagne ish colour in traffic near Glenlock Interchange.
(I was in the work truck.) --->>> MINT KITCHENS. ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/743/#findComment-6385703
Woulda been the missus driving. Still need to get that actuator off ya. Backed up my phone and lost numbers. SMS me when ya get a chance. Cheers
https://www.sau.com.au/forums/topic/30059-spotted/page/743/#findComment-6387098
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
