Spotted the white R34 with the shopping trolley wing on the road that goes past the airport just after 4 this afternoon followed by a silver R32 GTR on Majura Rd. For once I was in my GTR too :D
I was a bit caught up chatting so too slow for waves!
https://www.sau.com.au/forums/topic/30059-spotted/page/751/#findComment-6467998
Spotted what i thought was Troy derping around the parkway in the purple people eater, turns out it wasn't troy, just some other bloke with a purple 33
Think I saw this same car in on Constitution avenue this morning.. definitely wasn't Troy.. haha
https://www.sau.com.au/forums/topic/30059-spotted/page/751/#findComment-6468056
Spotted a bayside blue R34 outside the cafes at Woden, and a black R33 in the carpark over the road, about 5.30pm.
Also a light blue R31 chuck a u-turn on Athlon and then I saw it a minute later on Drakeford so it could have just gone the way it was going lol. Only putting it in here cos it looked lowered and not grandpa spec so I thought the owner might be on SAU :P
https://www.sau.com.au/forums/topic/30059-spotted/page/751/#findComment-6474981
Spotted Taylor in Tuggers a bit earlier turning onto Anketell. I was the knobhead on the downhill pushy who waved at the intersection ;)
Hahahahaha!!! Fark you popped a mean wheelie past the cop shop. Was tryin to catch ya but got stuck at the lights.
https://www.sau.com.au/forums/topic/30059-spotted/page/751/#findComment-6475055
hahaha that's nothing, on a good day when I'm going the other direction on Anketell I'll go along the bike path on the opposite side of the road - from Oakden Street just before bunnings all the way to Reed Street lights just before the cop shop ;) Which according to google maps is 400m LOL
https://www.sau.com.au/forums/topic/30059-spotted/page/751/#findComment-6475086
Damn! I'm stuffed after walking 400m haha
https://www.sau.com.au/forums/topic/30059-spotted/page/751/#findComment-6475102
When you say wheelie, are we talking like a manual or just pedaling on the back wheel?
If you are manualing 400m that's fairly solid!
hahaha just peddling, would need a downhill run to manual and I can't do it for shit on my big fat bike ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/751/#findComment-6475286
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
