silver M35 just before seeing the Blue 34..
Then pulled in behind a silver stagea at the lanyon servo around 430... really awkward.
Not sure if he was someone that recognised SAU'ers/Stagea drivers.. so for 5 minutes I made awkward on and off eye contact wanting to initiate friendship and sat there like a fridget .. which was reminiscent of my year 10 formal. Nothing happened as he drove away - reminiscent of my year 10 formal.
https://www.sau.com.au/forums/topic/30059-spotted/page/756/#findComment-6521439
Bahahahaa! I hate that!
It's like the awkward wave if they're sitting at the lights across from you.... if they don't wave back, you're both still sitting there, looking awkward.
At least the driving wave as you pass each other isn't so bad!
https://www.sau.com.au/forums/topic/30059-spotted/page/756/#findComment-6521455
Hate that. Had a silvia follow me for a bit, then pulled up next to me at lights. Had no idea if I should wave or not.
Also spotted a silver series 2 R33 on the way home, caught up for it and readied myself for a wave, as I looked over I realized it was a pretty girl driving, got all nervous and sweaty and had to drive off.
https://www.sau.com.au/forums/topic/30059-spotted/page/756/#findComment-6521747
Spotted a silver R33 heading into Tuggeranong this morning on Athlon Drive. Mutual light flashes.
Also spotted an orange wingless R33 with black wheels yesterday on Athlon heading into Tuggerenong, with P plates at about 1730ish.
That orange 33 gets a lot of attention in terms of being spotted .... He could just about start his/her own thread.
https://www.sau.com.au/forums/topic/30059-spotted/page/756/#findComment-6523084
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
