lol yes it does. Ultimate tunes guys have gone on a holiday for 10 days to tassy so il get the work done in jan some time. But no sin i have NOT picked up the injectors or a new boost controller yet. Still looking around. Can't wait till its tuned and off the run in stage...
https://www.sau.com.au/forums/topic/30059-spotted/page/789/#findComment-6674947
LOL there's no such thing as DONE no matter how hard you try to tell yourself.
I have been telling myself this for the past year.
Ohh just a turbo and tune and I will be fine.
Now I have a water meth kit to be installed.
Already purchased coilovers and new rims since then.
Now looking at a new radiator, intercooler and exhaust.
https://www.sau.com.au/forums/topic/30059-spotted/page/789/#findComment-6674975
What rims did you get kasko?
Also, it'll be a big moment when the chick from the orange skyline finally waves back. I wonder who will get the privilege!
Edited by Mitcho_7
https://www.sau.com.au/forums/topic/30059-spotted/page/789/#findComment-6675065
LOL!
Famous last words
under the bonnet... there is nothing left for me to do. apart from like go a big single etc but ill never do that. i bought a GTR for a reason. I mean i could stroke it but again thats something ill never do. Apart from that... its all been done haha
https://www.sau.com.au/forums/topic/30059-spotted/page/789/#findComment-6675073
those are pretty nice, grats. You going for the bat mobile black on black look huh
Yep :D
Was going to do matte black but after looking at it I like the way it is now.
Maybe a tad more low at the front.
But my exhaust is sooooo close to the ground.
Hence the new exhaust
https://www.sau.com.au/forums/topic/30059-spotted/page/789/#findComment-6675130
Who rolled your guards for you?
I like the black on black, looks the goods.
I did it myself haha
Ended up buying a heat gun + rubber mallet and went to town on them. Worked out great!
Cracked the paint trying to use a bar and no heat gun but that was before I got the other stuff
https://www.sau.com.au/forums/topic/30059-spotted/page/789/#findComment-6675879
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
