today at Philip around 5:10pm, white GTR V-spec ( black front lip ) parked beside me, I was in the video shop, saw him get out and have a little look at mine, I went to walk out and have a chat, got to the door and he was walking into the medical centre with a chick... DAMM !!
Ha that was me. Loving the black 33' goodness
https://www.sau.com.au/forums/topic/30059-spotted/page/923/#findComment-7182385
white 33 just now in Yarralumla, 2 doors down, hurd the same alarm as mine, thought oh I wonder if that's a skyline, he started it up, herd the rb growl! and said yep! stood beside mine with a ciggy, waved, not sure if he saw me, it was dark as hell! sounded nice as he slowly drove past! having a black skyline a night not sure if he saw minie, had a chick with him, maybe it was the same car as in phillip? didn't see the wing, did have a gtr bar, didn't notice the black lip tho ...
Lol Also me. I'm getting stalked
https://www.sau.com.au/forums/topic/30059-spotted/page/923/#findComment-7182391
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
