Yellow 34 southbound on the Monaro hwy yesterday around 1130, just north of Bredbo.
Flashed lights and waved but (reflection on windscreen) hard to see if any response.
And then...just the other side of Bredbo at 1620 the same car heading back north as I was heading home from CBR.
Definitely no response to waves, etc. this time.
Very nice car...looks like the one in Shell,s ID.
https://www.sau.com.au/forums/topic/30059-spotted/page/937/#findComment-7279119
I've recently sold it so it might well have been my old car. The new owner has a beard if you happened to see him!
https://www.sau.com.au/forums/topic/30059-spotted/page/937/#findComment-7279727
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
