Yep to the P's with a chick driver, if it's a 4 door I seem to see it a lot including having a loo break at Braidwood a couple of weeks ago.
Soz boss, to busy looking at the driver than the car. I know, I am letting the brotherhood down by such actions. I will cease to admire driver>Skyline. For now on it'll be Skyline>Driver. xo
https://www.sau.com.au/forums/topic/30059-spotted/page/958/#findComment-7409099
yeah - noticed the same thing Troy
Saw a nice R on carsales in red. Be nice to own it
http://ninemsn.carsales.com.au/private/details/Volkswagen-Golf-2012/SSE-AD-3045609/?Cr=2&sdmvc=1
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/958/#findComment-7409106
Have spotted a silver R33 at Fairbairn a few times.
Could be moi....although I haven't seen the GTR in your sig out there.
Are the Friday meets still at the museum or has that changed? I only just moved back to Canberra recently...
Spotted on Isabella drive pretty regularly...mint looking silver 33 GTR, looks like a series 3.
https://www.sau.com.au/forums/topic/30059-spotted/page/958/#findComment-7409812
Look for a shitbox red 318is. GTR doesn't appear out there very often :)
Which building are you working in?
https://www.sau.com.au/forums/topic/30059-spotted/page/958/#findComment-7410421
    • I would not replace the gauges. A well setup tune should never require any of that. I'm of the opinion that if you can't safely hand over a car to your parents to drive it's not fit for purpose and more engineering work should be done. Honestly I'm not a fan of external boost controller boxes either but if you have to you can shove the controller into the glovebox or something once it's set up. Tee it off the OEM MAP sensor. Also you probably want to put a two pin plug on the new solenoid, bolting it to the OEM location works. Just separate the wastegate line and compressor outlet so it will work on a 3 port solenoid, kevboost was walked through how to do this on an RB26, same idea just different locations on an RB25. You may have to remove the restrictor in the OEM hoses if they're still in there.
    • Yep, it's why in Australia we never brought in the 1 child policy like China.  China can't afford to use the shit they make in their own country as it's too much to risk having only one child...  Or maybe that's how they test their shit before they send it to Australia - they use the second kid that families had when they weren't supposed to as the tester?  They weren't supposed to exist in the first place so no loss if they succumb to a work place incident?  🤣
    • It's also the reason neither Duncan or I can own a car rotisserie
    • this is the reason we have more than one child right?
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
