Hey guys,
I've come across a complete R32 GTR rear cradle (everything but the brakes) and want to know if I can put the diff into my R32 GTS-T. My diff is on the way out (2nd one!!) and I'm fed up with it single spinning!
Does anybody know the process for this - do I need to change stub axles, half shafts, etc?
I've already looked around this forum and using Google and couldn't get any real info for the R32 GTS-T.
Any help would be greatly appreciated.
Bobby.
https://www.sau.com.au/forums/topic/300593-r32-gtr-diff-into-gts-t/
if you already got the entire rear cradle with everything except calipers, just bolt up the lot and just use your calipers and lines,
if you're missing the calipers/hubs/rotors, then it won't work, GT-R hubs and GTS-t hubs are different.
GT-R diff output shafts are different, so are their drive shafts and hubs.
Thanks for the reply mate, I have the GTR hubs, but not the calipers or rotors. The GTS-T rotors and calipers should fit, shouldn't they?
I apparently can swap the diff yoke from mine onto the GTR one... do you know if this is correct?
I appreciate your help :)
