Just wondering wat does a air filter do to your car? does it make it go any faster or does it save petrol or anything, just one of my mates recommend me get one, just can you guys help with this, because he said that its not good for my car me to have a sports exhaust/muffler system n no air filter (as one ive got no is preety old...11yrs)
any help wuld be great
thanks
https://www.sau.com.au/forums/topic/30060-air-filter/
man, you can have whatever combo you want... it's not that it's "not good for it"... you'll just get more performance with the whole lot... an after market airfilter sucks more air than a standard one and the more air you can get into your engine, the more performance you can get out of it...
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611268
You'll get a small fraction more power, but you'll let dust, dirt, pollen, insects etc into your engine which will make it wear out prematurely. So you'll get more power for a while but then things will become worn, compression will drop and you'll end up with a shitter.
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611323
That's after it's done a nice bit of damage to your compressor wheel :( Checking the turbo wheel on any car you're about to buy can be a good way of seeing if a decent quality air filter was used on the car.
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611324
thanks
nah, you dont need an air filter, get rid of it :(
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611426
waaaa?
if u buy a descent brand Pod Filter than your air is filtered the same as the airbox, just think of a pod filter as the airbox inside out kinda
u get what u pay for, buy shyt.. get shyt
bugs and dirt etc? ide love to see dirt or bugs get thru my K&N pod, actually i wouldnt see them if they were that small neways, not to mention theyd get burnt instantly with no trace or damage if they got that far into the engine
make sure pod is attached properly etc too
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611429
waaaa?
also think about the $170.00 defect notice from police if its not properly enclosed.
my 2c...not worth it without a proper box and cold air induction.
better off staying with the stock box that is a good heatshield and has a CAI and replace the element with a hiflow one..
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611432
now thats a better idea, put a pod in the stock airbox :(
but cmon u cant say dont put a pod filter on there cos cops with defect u for it, haha
in the many time ive been pulled over not once have they asked to see under my bonnet
on the topic of 'defects'
u do know changing the frontbar, exhaust etc is a defect too
now tell me u dont have ne of those or the 1000 other ones :)
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611444
Surely changing exhaust is legal? I mean, you go and get a stainless exhaust from Midas and you're changing your exhaust, yet of-course it's legal? PODS are another thing all together.
I have a POD, custom one made for me on my little Alfa 147. I've positioned it pretty down low, not so low that it's going to suck up water on a wet day, but low enough for it to get a lot of cool air to it (IE far away from the manifold/engine).
AND WOW! It sounds absolutely amazing. Growling, low rumbling noise on open throttle. It sounds better than my newly aquired R32 GT-R!!! Easily, the Alfa is a noisy little revvy car. I am so tempted to whack a pair of K&N pods on the GT-R but I'm not going to do it :( Keeping this baby stock.
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611450
It's a pretty major operation to put a pod in the stock airbox. It can be done but some mods need to be made. That's why most people remove it when fitting their pod, and why aftermarket pod boxes are so readily available. It's easier to fit one of these than to mod your original box to fit the pod.
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611451
ofcourse it is
But franks was talking about the defect fine or whatever and then suggested pod in a box.. which takes you around the pod filter defect problem :(
changing the exhaust is a defect if u dont have an emission test and certificate for it im fairly sure, the rules are different in diff states but last i herd this was the case. I certainly havent got mine tested, and i have changed my front bar, and pod filter and about 10 other things hehe
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611483
ok, yer cos i was looking at gettin a k&n one on special for 79.95 and my bro can install it, so does it make it sound better with the exhaust cos i got a 2.5" exhust system.
and is it worht getting a CAI done aswell? does it make much power i heard between 5-15kw's
let us know what you think
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-612462
no, i wasn't implying put an aftermarket pod inside a stock airbox, i am saying, replace the stock air filter element (inside the stock air box) with a high flow one.
here are my findings when i replaced my apexi super intake with a stock airbox and hiflow element.
http://www.skylinesaustralia.com/forums/sh...t=stock+air+box
on the notice of defects, you live in brisbane! theres the difference! performance cars in sydney are targetted all the time. i goto RBT's and i've had them ask me to open my bonnet.
on the subject of aftermarket exhausts, in sydney, as long as it complies with certain emmission tests and noise levels ie. under 90db they are fine. i believe you can goto an RTA inspection station to have your emmissions and noise checked for free.
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-612498
GTRboy: they're easy to install you could do it yourself....
There's 4 screws where the AFM connects to the stock airbox... undo these and take the stock airbox out...(you may have to take the top off and the filter out to do this easier..) Thes, screw your adapter plate for your pod on there, and your pod goes on your adapter plate and you tighten the ring clamp up with a screw driver... it'll take you roughly half an hour but don't be worried or anything its easy and if you do it yourself you'll save the dollars and boost your confidence with working on the car...
cheers man.
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-612503
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
